OK I'm running into a problem with my setup in
KMotionCNC, the jog buttons cause odd movement. If I hold
either inner or the outer button for any direction the
axis just cycles back and forth constantly switching
directions and never really moving. I'm sure it's
something I haven't configured correctly.
Axis Parameters:
My encoders are linear, with a resolution of 46.12
counts/mm so this gives me 1171.448 counts/inch.
Velocity. I'm setting this to the same max velocity I
used in the Kmotion setup but converted to in/sec:
40 counts/sec, 46.12 counts/mm ~ 0.87mm/sec, 0.034 in/sec
Acceleration, again setting this to what I set up in
Kmotion:
3 counts/sec^2, converted to inch is 3/46.12 =
0.065mm/sec^2 = 0.0026 inch/sec^2
Trajectory Planner I've left with the default values.
Jog I've set to the max velocity 0.034 inch/sec. For the
"Slow%" I tried default (25) and 1 and 100 didn't seem to
make a difference. This value isn't in the help file.
M0-M30 setup screen I've set everything but Halt and Prog
Exit to None.
M100-M119 all None
User buttons first one set to my init thread. Rest are
not used.
Tool/Setup Files. Left default. Main Dialog Face: Basic
2 Axes.
Main and Trajectory Planner screens below. I also am
unable to simulate simple g code (box), I get a dialog
with message of G Code error. Made sure no other program
is using kflop (Kmotion is NOT running).
Thanks again for any insight.
Greg.
